Dave Biehler shows us the 2013 road brakes with the R970 SL ultralight caliper, R970 EQ, longer pull ratio R979 SL, RRL singlespeed lever series for cross or road, retro looking RRL SR, RevoX and the CX9 and CX8.4 liner pull brakes.
Visit the TRP Interbike Booth on Mtbr here.
×TRP Parabox
Finally a reliable, race performance, hydraulic disc brake solution for disc brake compatible cyclocross and road bikes. Parabox's unique junction box master cylinder translates mechanical cable pull into smooth, powerful hydraulic braking force. The system includes front and rear calipers, pads, 160mm rotors, hydraulic lines, and all necessary mounting hardware.- Compatible with all makes and models of drop bar road brake/shift levers
- Colors, Black or White
- 451g/wheel (including calipers and rotors)
- $469.99
×TRP Parabox Caliper with Cable Routing
- $469.99
- $469.99
×TRP RRL Carbon
The RRL Carbon is the solution for riders looking for a race quality lever that is not integrated with a shifter. Ideal for single speeds, fixed gear or custom applications. The 100% carbon fiber lever blade is lightweight and ergonomically shaped. The hoods are flat and textured for enhanced grip. A built-in push button quick release system provides cable slack for quick wheel removal or to gain additional tire clearance on-the-fly when the conditions get muddy.- Sold as a set (left and right)
- 36 grams/wheel
- $109.99
×TRP RRL SR
The RRL SR transcends the ages by blending a race quality lever that is not integrated with a shifter with the classic styling trademarked by heroes of decades past. Ideal for single speeds, fixed gear or custom applications. The ergonomically shaped lever is drilled to enhance its beauty and reduce weight. The hoods are flat and textured for enhanced grip. A built-in push button quick release system provides cable slack for quick wheel removal or to gain additional tire clearance on-the-fly when the conditions get muddy. Available with gum or black hoods.- Sold as a set (left and right)
- 140 grams/wheel
- $99.99
×TRP RRL
The RRL Alloy is the solution for riders looking for a race quality lever that is not integrated with a shifter. Ideal for single speeds, fixed gear or custom applications. The anodized aluminum lever blade is lightweight and ergonomically shaped. The hoods are flat and textured for enhanced grip. A built-in push button quick release system provides cable slack for quick wheel removal or to gain additional tire clearance on-the-fly when the conditions get muddy. Available in anodized black or anthracite.- Sold as a set (left and right)
- 45 grams/wheel
- $59.99
×TRP R979 SL
Dual caliper supremacy reaches a new (Shimano 7900) audience with our R979SL. Offering the same race proven performance as our original R970SL, yet fully compatible with Shimano 7900 (6700 Ultegra) series levers thanks to longer caliper arms and increased leverage ratio, the R979SL raises the bar yet again. Forged CNC machined magnesium arms rotating on dual pivots, feathery titanium hardware, our innovative sliding quick release and mechanic-pleasing Inplace pad holders are the perfect chassis for the grippy TRP brake pads. These feathery light brakes come with two sets of brake pads for carbon or aluminum rims so you can ride, train and race with confidence.- Ultra-light dual pivot caliper brake - Shimano 7900/6700 compatible
- Forged / CNC machined magnesium arms
- Inplace Road CNC adjustable angle cartridge pad holders
- TRP Carbon and Aluminum compound pads included
- Titanium hardware
- Sliding quick release
- Color: Matte Black or White
- Reach: 39-49mm
- Weight: 125 grams per caliper
- Maximum Rim Width: 30mm
- $599.99
×TRP R970 EQ
Less is more. TRP’s focus has always been to create the lightest brakes possible while maximizing stopping power. The R970 EQ takes brake design to a whole new level to do just that. Forged CNC machined magnesium arms rotating on dual pivots, feathery titanium hardware, a familiar cam style quick release in addition to our innovative sliding quick release and mechanic-pleasing Inplace pad holders are the perfect chassis for the grippy TRP brake pads. These feathery light brakes come with two sets of brake pads for carbon or aluminum rims so you can ride, train and race with confidence.- Ultra-light dual pivot caliper brake
- Titanium hardware
- Cam and Patented Sliding quick release
- Color: White or Matte Black
- Reach: 39-49mm
- Weight: 114 grams per caliper
- $599.99
×TRP R970 SL
Less is more. TRP’s focus has always been to create the lightest brakes possible while maximizing stopping power. The R970 SL takes brake design to a whole new level to do just that. Forged CNC machined magnesium arms rotating on dual pivots, feathery titanium hardware, our innovative sliding quick release and mechanic-pleasing Inplace pad holders are the perfect chassis for the grippy TRP brake pads. These feathery light brakes come with two sets of brake pads for carbon or aluminum rims so you can ride, train and race with confidence.- Ultra-light dual pivot caliper brake
- Titanium hardware
- Reach: 39-49mm
- $599.99
×TRP R879
High performance and high value for Shimano 7900/6700 series users. R879 brakes are the perfect blend of race day performance and every day value. Forged aluminum arms and a familiar cam style quick release, these full-featured brakes are a perfect match for the latest Shimano 7900 style brake levers. Available in anodized black, the R879's include two sets of brake pads for both carbon and aluminum rims.- Maximum Rim Width: 27mm
- 139 grams/wheel
- List Price: $269.99
×TRP RevoX
Aluminum cyclocross cantilever brake.- Aluminum brake arms
- Integrated independent dial centering adjusters
- Fixed length straddle cable makes setup consistent and easy
- Semi-open stance
- Stainless steel hardware
×TRP RevoX Carbon
Carbon fiber cyclocross cantilever brake.- Carbon fiber brake arms
- Semi-open stance
- Titanium hardware
×TRP RevoX Carbon
- Semi-open stance
- Titanium hardware
×TRP CX9
Not everyone is a racer nor should every ride be a race. Cross bikes are the embodiment of cycling soul - able to venture over nearly all types of terrain swiftly and smoothly. The CX9’s linear pull design is compatible with most lever types and provides huge amounts of stopping power when the grades get steep or when your bike is loaded with enough gear to get you to the next continent. The super-low profile design also means panniers and racks do not interfere. Rely on CX9’s to stop you when you get there. Sold as complete bike set including all mounting hardware.- Linear pull brake
- Unique forged technology
- TT6 forged and CNC aluminum arms
- TRP road size cartridge brake pads
- Ti hardware
- Arm length: 90mm
- Color: Red, Black and now Blue
- Weight: 148g / wheel
- $149.99
×TRP CX8.4
Designed for cyclocross, these brakes will give you the ultimate in stopping power. The CX8.4 features 84mm length arms designed to work seemlessly with SRAM and Campagnolo shifters. Not content to just stop better, the CX8.4's also feature an integrated barrel adjuster on the noodle to make those on-the-fly adjustments simple! For newer Shimano levers, you'll want to choose venerable CX9. Sold as complete bike set including all mounting hardware.- Linear pull brake
- Ti hardware
- Arm length: 84mm
- Color: Red, Black and now Matte Blue!
- $149.99
×TRP Interbike Booth
TRP was founded on the idea of building the highest quality braking systems available in the bicycle industry. TRP Brakes are designed for superior levels of performance and durability achieved through the use of advanced production techniques, accurate processing and meticulous quality control. By using exotic materials such as Carbon Fiber, Titanium and TT6 Aluminum, TRP brakes set a new industry standard for lightweight and precise control. TRP brakes are extensively tested for reliability and safety on and off-road, and in the laboratory - by a company with more than 20 years experience designing and manufacturing bicycle brake systems.
