Marin Interbike Booth
Interbike VTSB
Mark Vanek shows us the 2013 Stelvio Ultegra Di2 updates to the T3 frameset construction, new headtube and straight blade fork system and the 2013 Cortina cross bike with disc brake setup, SRAM drivetrain and WTB i19 wheelset.
Visit the Marin Interbike Booth on Mtbr here.
Marin Interbike Booth Gallery
of
    Marin Stelvio Ultegra Di2
    • Model Category: Road
    • Model Name: Stelvio T3 Pro Ultegra Di2
    • Sizes USA: 49 52 54 56 58 60
    • Model Color: Clear Coated Carbon Matte w/Cyan Blue & Metallic Silver Decals
    • Frame: T3 Unidirectional Carbon with Internal Cable Routing, Power Taper Seat Tube and 1 1/8” to 1.5” Tapered Headtube, PF30 Bottom Bracket
    • Front Suspension: CXR Carbon with Tapered Carbon Steerer
    • Rear Suspension: None
    • Shift Lever: Shimano Ultegra Di2, 10 Speed
    • Derailleur Front : Shimano Ultegra Di2
    • Derailleur Rear: Shimano Ultegra Di2
    • Brakes Front: Shimano Ultegra
    • Brakes Rear: Shimano Ultegra
    • Brake Levers: Shimano with Integrated Shifters
    • Pedals: None
    • Crankset: Shimano Ultegra, 50/34T
    • Bottom Bracket: FSA Sealed Cartridge PressFit30 with Shimano Adapter
    • Chain: Shimano Ultegra
    • Cassette: Shimano Ultegra, 11-28, 10 Speed
    • Hub Rear: Easton R4
    • Hub Front: Easton R4
    • Tires: Vittoria Diamante Pro with Radial Casing and Kevlar Bead. 700 x 22c Front, 700 x 24c Rear
    • Rim: Easton EA90 AERO
    • Saddle: Prologo Nago Evo with Ti 1.4 Rails
    • Seatpost: Ritchey WCS 1 Bolt with 25mm offset, 350mm
    • Stem: Ritchey WCS 4-Axis 44 Threadless. 84/-6 Deg Rise
    • Handlebar: Ritchey WCS Evo-Curve, 4 degree sweep, shallow drop
    • Grips: Dual Density PU Micro Tape
    • Headset: Orbit C-40 Carbon with cartridge bearings
    • MSRP: $4,900.00
    Mount and seatpost tube detail.
    • Pedals: None
    • MSRP: $4,900.00
    Marin Stelvio T3 Pro Ultegra Di2
    Specifications:
    • Derailleur Front: Shimano Ultegra Di2
    • Pedals: None
    • MSRP: $4900
    Marin Cortina CX
    • Model Category: Cyclocross
    • Model Name: Cortina
    • Model Color: Black Midnight Matte w/Cyan Blue and White Decals
    • Frame: Marin CX 6061 Aluminum, Double Butted with E4 Anti-Flex Seat & Chainstays w/Disc Mounts
    • Front Suspension: RFE Cross Carbon Disc with Alloy Steerer Tube
    • Shift Lever: SRAM Rival, 10-Speed
    • Derailleur Front: SRAM Rival
    • Derailleur Rear: SRAM X0 Type-2
    • Brakes Front: Avid BB7 Mechanical Disc, 6” Rotor
    • Brakes Rear: Avid BB7 Mechanical Disc, 6” Rotor
    • Brake Levers: SRAM with Integrated Shifters
    • Pedals: None
    • Crankset: SRAM S350 Cross 46/36T
    • Bottom Bracket: SRAM Giga X Pipe
    • Chain: SRAM PC-1030, 10-Speed
    • Cassette: SRAM, Open Glide 1050, 12-27, 10 Speed
    • Hub Rear: Marin DiscLite w/ Cartridge Bearings, 32 Hole
    • Hub Front: Marin DiscLite w/ Cartridge Bearings, 32 Hole
    • Tires:Clement Crusade PDX 700 x 33c 120TPI w/Folding Bead
    • Rim: WTB Frequency Race i19 TCS Tubelss Compatible
    • Saddle: Prologo Kappa w/ Hollow Cromo Rails
    • Seatpost: Ritchey Logic Pro 2 Bolt with 25mm offset, 350mm
    • Stem: Ritchey Comp 4-Axis Threadless 84/-6 Deg Rise
    • Handlebar: Ritchey Comp Logic II Compact Alloy
    • Grips: Marin Plush Tape with Gel
    • Headset: FSA Orbit C, 1 1/8" with cartridge bearings
    • MSRP: $2,000.00
    Marin Cortina CX
    Type 2 SRAM rear derailleur with clutch.
    • Pedals: None
    • MSRP: $2,000.00
    Marin Cortina
    Specifications:
    • Pedals: None
    • Tires: Clement Crusade PDX 700 x 33c 120TPI w/Folding Bead
    • Seatpost: X-Fusion HILO 125mm with remote
    • MSRP: $2000
