Just In: Stan’s NoTubes ZTR Alpha 400 Tubeless Wheels
Feature Articles Wheels
The ZTR Alpha 400s come in three models. Un-built rims are available with 18, 20, 24, 28 or 32-hole counts.
With Europe’s fabled Spring Classics season just around the corner, and temperatures starting to warm up here in North America, we thought it was time to do a little rough-road wheel testing. To kick things off RoadBikeReview just received a pair of Stan’s NoTubes ZTR Alpha 400 Team tubeless alloy wheels.
In the coming weeks we’ll be putting them through the proverbial meat grinder on some of the dirt roads around Boulder, Colorado, as well as at a few local Roubaix-style races.
Obviously the primary feature of the Alpha 400 is the fact that it’s tubeless, meaning if all goes according to plan, we’ll be able to run lower tire pressure without the fear of pinch flats. In turn that lower tire pressure should also result in a smoother ride. At least that’s what the marketing copy says.
Already this year we’ve heard from the Stan’s NoTubes team who have committed to using ZTR Alpha wheels during training and racing throughout the upcoming season.
The Stan’s NoTubes team is running tubeless Alpha wheels for training and racing.
“Being able to run lower tire pressure is a huge advantage,” said NoTubes team rider Jake Wells. “You get the benefit of higher ride quality, without worrying about punctures. As a team we’ve been tracking our usage all year, and even during training there’s not been one flat. It’s really impressive. You get better handling up front and better energy transfer in he rear. It’s a true performance advantage.”
The 150-pound Wells claims he regularly runs his pressure as low as 85psi, and some of his teammates are going even lower. But being that I’m a wee bit heavier (about 25 pounds right now) we’ll start a little higher up the PSI scale and see how things go.
The Alpha 400 Team rim shares the same dimensions and Bead Socket Technology (BST) as its lighter little brother, the Alpha 340, but adds the triple channel and internal arch design seen on the mountain-bike-specific Arch EX and Flow EX rims. Stan’s claims this stiffens the entire rim while making tubeless inflation easier.
Stan’s skewers and hubs come stock.
Meanwhile, Bead Socket Technology is designed to lower the bead-tire interface so that tires lock more securely into place. The lower profile also reduces weight (the Alpha 400 Team set is listed at a reasonable 1495 grams). BST also means greater tire volume, resulting in increased traction, better cornering, and most importantly in the case of road riding, faster rolling. The idea is to convey the feel of tubular tires without the cost and hassle.
The Alpha 400 Team wheels come stock with Stan’s 3.30R front and rear hubs, which weigh 79 and 240 grams respectively. Spoke counts are 24 and 28. Rim widths are 20mm external, 17mm internal. Rim height is 22.6mm.
Stan’s skewers, DT Supercomp Black spokes, Hutchinson Fusion 3 road tubeless tires, and two 2oz bottles of NoTubes tire sealant complete the package. Retail price for just the wheels is $785. Max recommended rider weight is 250 pounds.
As for best applications, according to the Stan’s catalog rating system (1=Good, 5=Best) the ZTR Alpha 400 Team gets three out of five stars for road riding and four out of five for cyclocross. We’ll keep our testing on the road bike for now, but look forward to doing a follow-up come ’cross season where the idea of ditching tubulars and still being able to run low tire pressure is hugely enticing.
Just In: Stan’s NoTubes ZTR Alpha 400 Tubeless Wheels Gallery
of
    Light and Cheap
    The ZTR Alpha 400 Team wheels weigh in at 1495 grams per set. Retail price is $785.
    No Carbon Here
    Rims are alloy and weigh 425 grams all by themselves.
    Seal It Up
    NoTubes sealant and Hutchinson Fusion 3 tires complete the package.
    More Is Better
    Bead Socket Technology is designed to allow for higher tire volume.
    All Angles Addressed
    Fast Off The Line
    The Stan’s rear hubs have a 12-degree engagement system for quick and positive engagement.
    Lock It Down
    Stan’s Skewers keep things in place.
    Multiple Options
    Tubeless Ready
    Hutchinson Fusion 3 tires are 700x23 with 127tpi.
    Beefy
    The triple channel increase strength.
    Tough Testing Grounds
    The Gauntlet
    The true testing ground for any rough-road wheel – cobblestones.
An avid cyclist, Jason Sumner has been writing about two-wheeled pursuits of all kinds since 1999. He’s covered the Tour de France, the Olympic Games, and dozens of other international cycling events. He also likes to throw himself into the fray, penning first-person accounts of cycling adventures in British Columbia, Belgium, Brazil, Costa Rica, France, and Peru among many others. Sumner, who joined the RoadBikeReview.com / Mtbr.com staff in January, 2013, has also done extensive gear testing and edited a book on cycling tips. When not writing or riding, the native Coloradoan can be found enjoying the great outdoors with his wife Lisa.
  • aclinjury says:
    Rim width is at 20mm, which is a little behind the curve a bit. Manufacturers are now moving to 23mm width. I believe the new DA 9000 C24 tubeless wheelset has 23mm width. I think a wider rim and tubeless will enable even a more stable and supple ride.
